- Feb 8, 2005
Ok...I have always liked the cotton balls kneaded in Vaseline..Carmex etc..so was out doing some experimenting tonight...and wondered if I kneaded some nice fatwood shavings/dust into the mixture if it would make a stronger burn or perhaps even a more sustained burn..
From what I can tell after about 3 comparisons of a pure Vaseline saturated c.ball vs. a Vaseline saturated c.ball + fatwood shavings...I get a little hotter flame with the fatwood and a more sustained burn by like 10 secs..so I'm wondering what others have experimented with to enhance the standard pj + cotton ball that works well?
To clarify..I used a saw blade on my leatherman to gather as much of the fine shavings as I could off of some pretty decent fatwood..and then kneaded it thoroughly into what ended up as about a 1/3 inch diameter tight balls of cotton/pj/fatwood mix...to have stuff to carry during the winter months in a secondary K&M match case..my goal being to eliminate the need for anything but semi-tight wood curls to get a fire going in a "it's freaking cold..I wanna fire now" scenario using only a firesteel to get a sustained fire going...from past experiences, that extra few seconds of a sustained concentrated initial fire source gives more time to pile on curls and then work up to the pencil lead/pencil sized starters leading to a sustained fire without the cold biting the ol' fingers to hard
The wind was pretty low tonight, but found the enhanced cotton balls lasted roughly a minute and ten seconds.
Thanks for your suggestions.
