- Mar 6, 2000
…with a smaller knife? This is a question that I can most often answer with a yes. I’m slowly realizing that the reverse is not so commonly the case.
We ate at a soup and salad joint last night, and they give you a large chunk of baguette on the side. I whipped out my OHO, which is a 3.5” blade. Naturally, I cleaved it into two manageable halves with one pass. My g/f handed her’s to me for similar alteration. Could I have done it with my 91mm SAK main, or my 3.25” stockman clip main? Yes, no doubt in my mind. It just would’ve required working the blade around the loaf 360, as I would do with a bagel, for example.
Then I got to thinking. What about the past several uses of that stockman and SAK. I’d used the sheepsfoot in cutting the end off of a large panel of Styrofoam insulation for my sliding glass door. That would’ve been awkward, or perhaps even unsafe, done in the same way with the larger knife. Now, if I had laid that panel down onto a sawhorse, or even table top, and extended the panel’s edge outward…no problem. But, I merely laid it onto the pile carpet, knowing that small blade would only be going into the top ¼” of the pile, doing no harm.
I used the small SAK blade in cutting open the small plastic bottle of dressing for my co-worker to get the rest of the goodness out w/little waste. Extremely awkward to attempt with a longer, wider blade. Cleaning under my nails? That’s a small-blade no-brainer. Food packages, opening the average boxes and clam packs? Control is the name of that game. Admittedly, nothing trims the excess ‘neck’ off of a dwindling bag of chips like this knife, LOL. But I’ve done so with the little guys, too. I just fold over the excess and cut along the fold.
Has anyone else migrated to smaller EDC/s with this sort of reasoning? Or, what reason/s, do you maintain for continuing to carry a blade, say, over 3”?
