I need a way to contersink holes for my handle slabs. I am putting micarta handle slabs onto a CRKT Ryan Model 7, and need to countersink the torx head screws. Unfortunatley I don't have a countersink, and have not had to much success drilling the correct size hole, and then a larger partway down that. Any other ideas? I finished one side, and while trying to enlarge the holes on this side I drilled all the way through, and the screws wouldn't hold on the slabs. I ended up putting the screws in place, and then epoxying the slabs on. If I can't countersink the other side I guess I will end up doing the same thing. The only problem with this is that it is the liner lock side which has many cutouts, and I am not sure the epoxy will make a good enough bond. Thanks in advance.
Erik
Erik
