I have noticed slight fraying of insulation on the wires underneath the heat pads (I am sure there is a more correct name for those) on my electric range.I don't quite see the exposed metal though.
1) Can this be a fire hazard?
2) If so, would this be a fire hazard when the thing is in use, or at anytime? In other words, can it trigger a fire when I am away from home?
Heaters:
If the window is opened briefly for ventilation and the heater (I don't know what kind it is, it is somewhere outside my apartment) is running a little harder to keep up with the frigid air, can this be a fire hazard?
Finally, do candles that are electrically melted (via plug in small candle heater) emit carbon monoxide like burned candles?
Thank you much, and I hope these are not too retarded.
Heaters:
