Hey, had a couple quick questions before i get working on a tanto design i drew up.
1) does the blade bevel continue down the tang so as to allow the habaki hole to fit up correctly? or do i just need to do the final hammering on the blade (pre hardening i'd assume) and have it form to it that way?
2) i'm doing stock removal on w2 and will be claying the blade for a hamon (have done a number of knives this way before, so not unfamiliar with the process), and quenching in parks50. i intend to cover the flat of the bevel and have ashi lines extending down towards the blade, i use 1/8" of satanite. the blade length from end of the habaki to tip will be 8.5". do i need to account for the blade bending towards the tip on heat treat, or can i do my normal method of grinding the sweep in? my impression was that you can expect the bend to form if water quenching, but parks should keep it relatively close to the ground shape, is this correct?
thanks!
thanks!
