I recently acquired 2 knives in s35vn for free because the owner could not grind out the chips in the blades. I have been using my course dmt bench stone but it is taking forever. Would a sic stone work or do in need an extra course diamond.
Diamond is at least 3x harder than silicon carbide.
Coarse silicon carbide will work just fine, and will allow you to use higher pressure to speed the rate of removal. It'll be at a hardness disadvantage compared to diamond, but going coarse/high pressure enough more than compensates for the light touch you have to use with diamond. It'll still be bit of a pain trying to hog metal off a high-alloy blade, but it'll at least be a little faster.
I am going to try your manticore and see how that works. I don’t want to spend the money on another diamond stone right now.
If you ever do want a faster cutting diamond stone I would look at the coarsest Venev stone they make,I really enjoy my F60 Metallic CBN stone and out of any stone I have nothing cut's as fast as it and just blows threw any steel you throw at it.
wade7575, thank you for your thorough reply about the CBN stones! That was very informative. Very impressive about the reprofiling time, too!
The problem is that I only use benchstones. I didn't realize these only come in sizes used in guided systems. Much of my knife use is in the wilderness, where I only carry minimal sharpening supplies to keep the weight down. I like to do all my reprofiling and sharpening at home freehand so I can keep in practice.
I appreciate your post and will check with Gritomatic once in awhile to see if they have started to make these stones in benchstone sizes.
