- Aug 20, 2011
Which is best and which is worst. I have my own opinions but i'm curous about other peoples thoughts and experiences.
Well i just purchased a team gemini light brigade with the intentions of using it as hard as I use every other knife i own.... i really hope the hollow grind does not hold it back!!!
That's what I'm thinking. I don't need a chopper but battening is important and the TGLB looks like it might fall short in that respect.
I have battoned a metric sh*t ton with my LBTG and haven't had a single problem even AFTER knocking down the shoulder of the v edge as a start to a convexed edge.
Beat the crap outta your TG's!!! They LOVE it and your NOT gonna hurt them.
I don't have a Team Gemini of any sort but the convex will not hang up in the wood like the FFG will. While the FFG blade is a wedge it is a very thin wedge not like a splitting wedge. It will work but not as effective as the convex grind. At least this has been my personal experience. Saber grind is also a good choice for wood processing as it is a little thicker wedge at a larger angle and it works great in several knives I own. I do not have any experience with large hollow ground knives and have not seen many that were not intended to be fighters. Hollow ground is great for slicing which is what I would imagine is what it was designed for.
I believe convex would be strongest for batoning and chopping wood because the cutting edge is so robust. You do not sacrifice any significant steel when batoning with a convex edge (granted it isn't too thin), where as with a v-edge...you can notice a difference in sharpness even after a few logs...in my limited experience. Batoning with a hollow grind?! I would imagine that it would really mess with the edge geometry, as the hollow grind is designed to bring a very fine slicing edge to a blade regardless of the stock thickness. The diagram will help support my claims. A fully convexed knife, or a thick saber grind with a zero edge grind (like a 'vexed FFBM) will go through a small to medium sized tree faster than Oprah can devour a cupcake.
you folks are being way too paranoid. INFI is tough stuff. Hollow ground or not, it's not going to matter.
