Hello all. I'm new to using forums, so please excuse me if I'm doing this wrong. I've made 3 blades out of CPM 154 and all have warped! I'm using the standard heat treatment- I start with a cold oven, ramp up to 1450F for 15 minutes, ramp afap to 1950F and soak for 30 minutes. Then I air cool clamped between aluminum plates using compressed air aimed into the opening in the plates. I then have put them on my machinists style surface grinder and take about .002" passes. when removed from the magnetic chuck, There is a warp. I was able to correct the warp slightly by flipping the blade over and grinding the other side, but it's hard to judge how much to grind to correct the warp. I then cryo treat with Ln2 overnight and temper twice @ 300f for a hardness of 60-61 RHC. The last blade was a filet knife. It actually bowed like a Japanese sword would do. I wonder if the compressed air is at fault. Any help would be greatly appreciated!
Bob
Bob
