CPM 20cv, M390, CTS-204p
I'm looking at 2 ZTs and having trouble deciding which to get... one is a 0620cf in 204p, the other is a 0630cf in M390. I have absolutely no experience with either of them (or 20cv) and I was wondering what you guys thought?
As far as I understand they're pretty similar apart from country of origin. Figured we may as well throw 20cv in there too because if I'm not mistaken it's the same class of materiel...
thanks in advance fellas
Reputed to be fairly similar
However having a 204p and a m390 from ZT I have some preference for the m390
However both have different grind so my perception may be biased
Have you noticed any difference in edge retention or ability to take an edge?
They all are very similar in composition to the point I count them as a same steel.
In theory M390 and CTS-204P will be more refined than CPM due to better PM technology but from my experience they are all the same.
I have never had a ZT knife, but I have had all three steels from other makers. I would recommend getting the knife you like most. You won't notice much difference in performance. If I had to decide, I would say I like, in order, 20CV, M390, then 204p. But I think blade geometry and HT has more to do with the choice than the steel itself.
For me the M390'is easier to sharpen and to take a better edge
For edge retention I would say they are the same
In M390: ZT0350, Benchmade large and mini griptilian
In 204p: ZT0562CF
Sharpener: spyderco sharpmaker
you should not notice any differences between these steels. there composition is basically the same, they have slightly different amounts. m390 is using 3rd generation PM process which uses a smaller micron grain size than the other two.
depending on the heat treat and blade geometry, a user will not notice any difference at all.
^^^what he said
Except for the addition of Tungsten, like 0.65% vs 0.60%, BU's M390 is a newer generation of this powder steel. Carpenters steel is considered Gen2 while BU is considered Gen3. Only the most prolific blade grinder would be able to tell the almost imperceptible difference in the characteristics of these alloy's. The true beauty of these (IMO) is the very high Chromium content (20%) AND the ability to hold a scary sharp edge all the way to 15 degrees (per side) while being tough as hell. 60-62HRC is the working range of this steel.
Microtech is using M390 in it's Stitch auto, and that is the sharpest out-of-the-box production knife I have ever handled. The secondary grind is so fine yet so durable. Cut myself something crazy when my finger just bumped the edge.
Latrobe doesn't list the original Duratech 20CV on its site anymore, they now list CPM 20CV which I confirmed doesn't show up on CPM's product list.
some quotes from the spyderco forums
Crucible Steels are 1st Generation - CPM Steels
Carpenter Power Steels are 2nd Generation
Bohler Powder Steels are 3rd Generation
The difference is refinement of the process allowing for more even distribution of the Alloy, finer grain structure and that increases toughness and allows for higher hardness.
Better is a matter of opinion between the 1st, 2nd and 3rd generations and that depends on what steels they are talking about and the HT.
Remember when talking about steels we don't get anything without giving something else up in the process.
N. Brian Huegel wrote:
As part of my interest in understanding powder metallurgy, I sent an email to Ronald Long at Carpenter Technology Corporation. He is the Commercial Manager of the Knife Blade Products division. He has graciously allowed me to share it with the forum. Here is a portion of our correspondence.
Q: Per this Spyderco forum thread, in what began as a discussion about their latest Mule made with Böhler M390, I have attempted to compare / contrast with your CTS-204P. As part of the discussion, it has been brought up that your powder metallurgy is 2nd generation whereas Böhler’s is 3rd generation.
A: From one of Carpenter’s R & D managers: “The first generation powder product that was originally produced in Sweden by Erasteel and Anval (now CPP AB) consisted of air induction melting in a top pouring furnace followed by pouring the molten metal into a tundish from which the molten metal is bottom poured out of the tundish and is atomized to produce a coarse powder, typically -1000 microns or -500 microns.
The second generation powder product as practiced by Erasteel, CPP AB, and Böhler, consists of the first generation air induction melting process followed by pouring the molten metal into a heated, refining tundish called an “ESH” tundish (Electro-Slag Heated tundish), where the molten metal is heated with graphite electrodes (Erasteel and Böhler process) or a plasma torch (CPP AB). The refining tundish permits the molten metal to be purified (reduce the amount of inclusions). After refining, the molten metal is poured out of the bottom of the tundish and is atomized to produce a coarse powder, typically -1000 microns or -500 microns (the same powder size as the first generation process).
Böhler’s third generation powder product consists of the second generation process followed by a modified atomization process that produces a finer powder, typically 250 microns. Böhler claims the finer powder reduces the presence of coarse carbides compared to the first and second generation, coarser powder.
As noted above, CPP AB uses the second generation powder process. CPP BVL (BVL is our facility in the US and our source for CTS 204P) uses both air induction melting and vacuum induction melting coupled with the use of reticulated refractory filters in its tundish to produce 150 micron powder (finer than Böhler’s powder) for P/M tool steel millform products. CPP BVL’s powder manufacturing process does not directly compare to the European classification system of “first, second and third” generation powder processing. BVL’s vacuum induction melting + filtration process plus the use of -150 micron powder is cleaner than the third generation process. The air induction melting process + filtration process plus the use of -150 micron powder is equivalent to the second generation process with a finer powder than the second generation process.”
From Ron: As you can see it is not exactly an “apples to apples” comparison when one puts the processes side by side.
Effectively, from dimensional perspective, our “2nd generation” process produces a finer, 150 micron powder than their “3rd generation” process which is 250 microns. And I don’t believe they would argue that their 250 micron material would have finer carbides than our 150 micron material.
The other issue is product cleanliness. I have asked for information on product rejection rates for inclusions and have yet to find an example. I am not saying they do not happen; just that folks are having problems finding the last time it did happen. In my short tenure here I have not dealt with an inclusion. I will look to get you a better definition of cleanliness relative to our product.
Regards,
Ronald Long
Commercial Manager- Knife Blade Products
His only concern in allowing me to quote him and Carpenter is that he does not want to get into a situation where he might sound like, or be accused of, being critical of Böhler-Uddeholm which was not his intent. I do not believe that this will be the perception and I sincerely appreciate his explanation and knowledge on the subject. I also invited him to participate directly with this forum and also encouraged him and Carpenter to consider establishing a forum or sub-forum of their own. Time will tell if this comes to fruition, however, I do believe that the above is a definitive expression of Carpenter Technology’s deep commitment to our industry and the future of cutlery steels.
To simplify this... basically there is very little difference between them, and nothing that the user would ever notice in use (again depending on HT and blade geometry).
This is my first ZT, and I ended up purchasing the one in 204p...
Only to find M390 on the blade which is great because I wanted M390 but I liked the design of this knife better than the other lol
I suppose it's worth noting I can't even find a 0620cf in M390 for sale... bladeops has them (out of stock) listed for $240. I paid $183.
On the Kai website it lists it as the 204p. Was the M390 a sprint run or something? And did I get a deal considering the price of the ones listed in M390?
They ran out of M390, so now they use it sparingly.
its all based on how much of which they can get at the best prices.
What id like to know is... ZT's heat treatment on S35vn is super soft, as repeated tests show it as a poor performer for edge retention.
is the heat treatment for ZT's 204p/m390/20cv also softer than other manufactures? i noticed my 204p/m390 from ZT lasts a very long time, unlike the s35vn i have, but i havent put these to the test with my other brands with the same materials yet of 204p/20cv/m390. would be great for someone to test (i aint got time for that atm).
[video=youtube;yDxSG6xbl7M]https://www.youtube.com/watch?v=yDxSG6xbl7M[/video]
  • Like
Reactions: vba
First I have heard of ZT having shitty steel.
i wouldnt say shitty. just not particularly good with edge retention in cutting tasks with s35vn. no other tests were done, it may excel at other tests, wouldnt know. am not saying there m390/204p/20cv is the same, im saying i dunno if its soft in comparison to other brands... as it has not been tested to my knowledge. BUT ZT has a track record of low HRC#'s, not optimal, which is not bad per say. its better for a mass production knife to be soft, as its easier for the customer and them as a company.
