- May 29, 2004
What hardness should I use with CPM 3-V in an axe that is 36" long, with approximately a 15" cutting edge, strong 1/4" thick. I'd like for this thing to be able to split wood among other things. Thanks, Steve B
Low temp or high temp temper?What hardness should I use with CPM 3-V in an axe that is 36" long, with approximately a 15" cutting edge, strong 1/4" thick. I'd like for this thing to be able to split wood among other things. Thanks, Steve B
Not sure where you got that from. It just didn't sound close to me, and when I checked, 3V at 62HRC has about 25ft lbs, where D2 at the same hardness will have no more than 5ft lbs, according to the data provided by L Thomas in his book. And I personally wouldn't use the high temper especially for that application, as it increases wear resistance (a little bit), but really decreases toughness by robbing the steel matrix of carbon to make those tempering carbides. Take a look at the data and videos Nathan Carothers did with impact performance on 3V with low vs high temp tempering.Low temp or high temp temper?
58-59 HRC for high temp, 60-61HRC for low temp temper. Don't go beyond 61 as toughness dips considerably. Almost D2 zone.
Internet. Was searching for data on 3V and found some data with V and C notch impact testing. 59HRC was the sweet spot in height and hardness gave it a bigger dip than softness. @63HRC it was low as D2.Not sure where you got that from.
It seems he was going for low temp Bainite formation. As he never displayed the aust temp, I guess he was going for more carbon in solution and with low bainite avoided an plate martensite. Also I found some research on low temp bainite and it really looks very good for toughness sake in knives. Just nobody made an edge retention test to see how that goes.That Bluntcut guy might have a process for it, but I don't.
They should. As always, when in doubt, give it to a professional.I guess I will be using Peter's to heat treat, hopefully they can dial this in.
I wish that was trueThey should. As always, when in doubt, give it to a professional.![]()
