Originally posted by Geode
...CPM 420V is more stain resistant, wear resistant, and holds an edge longer - however is harder to sharpen.
Does CPM 420V take the same razor sharp edge D2 does?
Is it that tough to resharpen (if the knife does not get completely dull)?
Geode
For folders, I'd take 420V. It definitely has a finer grain structure than D2, and all things being equal, will take a finer edge in theory. Neither is a particularly tough steel (understatement). 420V if treated to Rc58-59 will hold an edge better than D2 at that same hardness. If D2 is taken up to Rc60-61 as it can be easily by most all makers if they wish, well, I'm not sure 420V would win or not. It would probably vary depending on the task. Hardness matters in terms of both abrasion resistance and resistance to a rolled edge.
420V is definitely and notably more corrosion resistant. D2 is as close to being "relatively stain resistant carbon steel" as it is to being "barely stainless steel". Depends on the stock and the heat treat and the finish. YRMV.
Buy diamond stones as mentioned and never look back. If you buy diamond, you won't notice enough difference in sharpening to matter. If you buy natural stones, both will be hard to sharpen due to Vanadium content (1.2% in D2 and 9% in 420V). Vanadium carbides run Rc82-85, while natural stones run (I think) Rc65 +/- a few points? Anyway, diamond is up around Rc90 if memory serves, and it does the job on high alloy steels.
Darrel tends to keep 420V at Rc58 I think, and D2E at 58-59 (this from memory, so somebody straighten me out if this isn't quite right). At these hardnesses, I must say that of the knives I own, I can only get a Dunkerly hunter in 52100 any sharper than my DDR pieces.
I have:
1. EDC in D2E
2. Apogee in Damasteel
3. ALB in 420V
4. Arclite in 420V
I am not sure what Darrel does, it may be just very competent heat treat and keeping them a point or two on the softer side, but they are fine blades and take an outstanding edge... the hair jumping, clean shaving edge that I can't get on all my blades. I can't say that I've tested them side-by-side with other steels for objectivity, so edge holding I'll just have to say "good enough for me" and for sure very good, including the Damasteel (which surprised me. Damasteel is a combo of two powder metallurgy steels, one a clone of ATS-34 called RWL34, the other a PM clone of 12c27. It actually holds an edge very well, subjectively. I do have some other stainless damascus that isn't very hard and you can tell).
