Again, here's some specs...this time on CPM 420V:
-=[Bob]=-
CPM 420V (AISI 420 Mod.)
Description
CPM 420V is a unique tool steel made by the Crucible Particle Metallurgy process.
It is designed from a martensitic stainless steel base analysis with added high
carbon and vanadium for exceptionally good wear resistance. CPM 420V offers
significant improvements over CPM 440V in both wear and corrosion resistance.
The exceptional wear resistance and good corrosion resistance of CPM 420V make
it an excellent candidate to replace 440C and other corrosion and wear resistant
materials, particularly where increased wear resistance is a primary concern.
Typical
Applications
Injection and extrusion screw and
barrel components
Wear components for food, plastic,
and chemical processing equipment
Pelletizing knives
Slitters, cutters, chipper knives
Bearings, bushings, cams, gears,
valves
Rolls
Chemistry
C 2.20
Cr 13.00
V 9.00
Mo 1.00
Heat
Treatment
ANNEALING TEMP.
TYPICAL ANN. HDN. BRINELL
PREHEAT TEMP.
AUSTENITIZING TEMP.
QUENCH MEDIUM
TEMPERING TEMP.
TYPICAL APP. HARDNESS HRC.
1600/1650F
255/277
1500/1550F
1950/2150F
AIR/OIL/SALT
400/750F
56-58
-=[Bob]=-
Description
Typical
Applications
barrel components
Pelletizing knives
valves
Rolls
Chemistry
C 2.20
Cr 13.00
V 9.00
Mo 1.00
Heat
Treatment
ANNEALING TEMP.
PREHEAT TEMP.
AUSTENITIZING TEMP.
QUENCH MEDIUM
TEMPERING TEMP.
1600/1650F
255/277
1500/1550F
1950/2150F
AIR/OIL/SALT
400/750F
56-58
