- Jun 7, 2022
I recently got a lot of cpm cru wear. And was wondering if anyone had a good step by step on how to heat treat it. Any help would be appreciated
Actually, cryo converts retained austenite into martensite which increases the hrc. The temper cycles relieve stressors in the steel which lowers the hrc but increases toughness.To each their own but from what I understand cryo soak is used to lower RA. With a high temper, around 950F and above, the RA is converted into secondary carbides so if one is using high temper then cryo is not needed.
