CPM-D2 Heat Treat...unusual results?
First I’ll start by saying I have successfully heat treated 25ish blades mainly A2 and D2. I I decided to give CPM-D2 a try so I ground 2 blades from 1/8” precision ground stock. I decided to try my normal D2 recipe. After completing my temper cycles I decided to start working on the finish grinding. I use a 100lbs magnet to flat grind the blade against my flat platen. When I stuck the blade to my magnet it fell on the floor. I was little dumbfounded so I though that something was wrong with the magnet so turned and stuck it to the side of my grinder and it practically jumped from my hand. Magnet was fine. I then tried to stick it to both blades and they both barely stuck to the magnet. Has anyone ever experienced this? Any idea on the cause?
Where did you get your material from? Sounds like you got a piece of something like 304 stainless...
If it's really non-magnetic, it definitely is NOT D2, or any tool steel for that matter. Did you check the hardness after heat treat?
You have an excessive amount of retained austenite usually caused by too high aus temp.
Wrap balde in ht foil, heat to 1350 for 4 hours, air cool to room temp, reharden blade at 1875f, sub zero or cryo quench, temper.
Make sure it is D2.
Hoss
Thank you for the info. I feel confident that the material is CPM-D2 and was magnetic pre -HT. I’ll check my thermocouple it could be off. I quenched at 1835 and then sub-zero for a couple hours. I have no idea the hardness other than a file skated cleanly.
