Cpm S30v
The rumor that Crucible was developing a new CPM stainless steel for the knife industry is no longer a rumor.
The material is done and available.
We are stocking the material in our Dallas, TX warehouse along with all of our other knife steels.
If anyone is interested in CPM S30V or any other knife steel, their number is 800-365-1168.
If anyone has any specific questions regarding the new material, please post them here and I will check back periodically to answer them.
Many thanks to those who have helped us with this project and their patience.
Ed Severson - Crucible Steel
Thanks Ed, Jerry Hossom has a thread about CPM S30V on the Shop Talk forum. He seems quite excited about this new stainless. I was unable to find any information on your web site about it though. I sure would like to find out as much as I can about S30V, where can I get more Info?
We're about two weeks away from finalizing a full data sheet with all the property data.
Right now we have a preliminary sheet with the heat treatment data.
I will have this added to the web site as soon as the final data sheet is finished.
Thanks Ed, I will be looking forward to getting this information on what looks to be another great product that you have developed that will enhance the knive industry. keep up yhe fanastic work.
Originally posted by KWM
Thanks Ed, I will be looking forward to getting this information on what looks to be another great product that you have developed that will enhance the knive industry. keep up the fanastic work.
Ditto what KWM said!
Ed, could you post the alloy makeup? C, Cr, V, Mo, etc...
Could you offer some general commentary ... a few questions to start things off:
1. How much Chrome in S30V? How "stainless" is S30V compared to say 3V, D2, ATS-34, BG-42, and CPM420V?
2a. How tough is S30V at Rc60 compared to A2, D2, 3V, 420V... all at Rc60?
2b. Another angle on toughness question. How much harder could you run S30V while staying as tough as BG-42 at Rc60.
2c. How much harder could you run S30V while staying as tough as CPM420V at Rc60?
3. Where do you expect edge holding (slicing) to line up... again compared to say D2, BG-42, 3V, 420V all run at Rc60?
The nominal chemistry for S30V:
Carbon: 1.45
Chromium: 14.00
Vanadium: 4.00
Molybdenum: 2.00
The material is a true stainless and the corrosion resistance is equal to the levels of BG-42, 440C, 154CM, etc.
Official toughness data is still being compiled but our research data shows that at 60 HRC S30V is tougher than D2, BG-42, 154CM, S60V, and S90V. It is not in the same ball park as CPM 3V, but will give A2 a run for its money.
You can realistically run S30V at 60-62 HRC and be tougher than S60V and S90V.
I'll leave edgeholding to the field. We believe it will give results close to the higher vanadium versions, but the proof will come from the makers and their tests. Jerry Hossom should give a good run down when he completes his knives.
Ed, this looks to be a tremendous stainless steel and from all reports it is also very reasonably priced. As I stated in an earlier post, keep up the great work. This industry needs more products like this and it seems that your's is the company to do it.
One of Crucible's handbooks shows A2 to be near twice as tough as D2 at Rc60, so A2 is pretty tough if heat treated well, right at Rc60 (it has a local toughness peak at this hardness, if I recall correctly). Nearly any steel that can be run at Rc60 or higher without brittleness problems will be a good slicing type edge holder. Add Vanadium at Rc60 or higher and you get into the "really good to great" range for today's steels. And edges don't roll as easily in the Rc60 range (e.g. Stellite/Talonite tends to roll).
I made a comment on these forums probably 6-8 months ago that if Crucible delivered on their design goals for S30V, it could turn out to be about the best balanced "stainless" steel on the market...
* surpassing BG-42 in that category
* giving 420V some competition on 4" and smaller blades where a bit of additional toughness was desireable
* and giving those in search of a stainless-range "big blade" that needed some toughness (which for me they do) something they could actually bank on as the best overall steel.
It would appear that Crucible has put forth a great piece of engineering effort, and may be on their way to actually delivering such a product. I, for one, truly appreciate their efforts at pushing the boundaries for what is a relatively small niche, hand made knives. I hope the rest of the knife buying public appreciates this costly bit of engineering and rewards Crucible with demand.
And I look forward to seeing the "proof of the pudding" on toughness and edge holding, a tough balancing act. Hats off (and hopefully a fresh round of orders) to those makers who do the testing of this new product early-on.
Carbon: 1.45%
Chromium: 14.00%
Vanadium: 4.00%
Molybdenum: 2.00%
Comparison time, based on metallurgy/content, Ed Severson's commentary, and some educated guesswork:
D2
Carbon: 1.4 - 1.6%
Chromium: 11-13%
Vanadium: 1.1%
Molybdenum: 0.7-1.2%
420V
Carbon: 2.3%
Chromium: 14%
Vanadium: 9.0%
Molybdenum: 1.0%
BG-42
Carbon: 1.15%
Chromium: 14.5%
Vanadium: 1.2%
Molybdenum: 4.0%
S30V compared to D2:
* CPM process especially, but secondarily the high vanadium content should help refine grain structure significantly vs. D2. That means finer edges if you want them, and plenty good response to coarser stones for a grabby edge if that's what you want (D2's forte). May have less propensity for ripping out big carbides during extended slicing.
* More Vanadium content in S30V means more carbon is tied up in vanadium carbides (very hard... edge holding & abrasion resistance benefit). Couple more vanadium with more chrome, & that means less carbon tied up in chrome carbides I'm guessing, and therefore more free chrome at surface to oxidize to Chromium oxide which boosts corrosion resistance (iron oxide) vs. D2.
* similarly high carbon content should yield similar attainable hardness figures (also born out by Severson's comments that Rc 60-62 is very doable and useable)
* Crucible's tests show better toughness than D2, and more toughess is always good if edge holding isn't compromised. D2 is well below A2 in toughness, so S30V should fit in between somewhere.
S30V compared to 420V:
* S30V has less Vanadium, so at the limit, less abrasion resistance.
* still apparently enough free chrome to be similarly stainless, but I'd guess S30V would be a bit below 420V here. Would like to see lab salt water or other testing results. The old "slice a lemon and don't clean knife for a day" test would be illustrative also.
* Clearly if S30V give's A2 a run for it's money in toughness dept, it'll significantly surpass 420V in toughness, the benefit for trading off somewhat lower ultimate edge holding.
* grain structure should be similar, i.e. CPM process.
S30V compared to BG-42:
* CPM process should yield as good or better grain structure refinement given optimum heat treatment
* more Vanadium + plenty more carbon = better edge holding and similar if not higher attainable hardness
* same amount of chrome, along with more vanadium but with more carbon, means what... corrosion resistance should be similar probably?
* tougher is better if edge holding not a tradeoff, and it shouldn't be with so much vanadium.
* S30V trades molybdenum for vanadium. This should help grain structure, and help edge holding a bit as vanadium carbides are harder than molybdenum carbides. Yet there is enough molybdenum to prevent pitting type corrosion.
* one guy on the forums (a hunter type from Colorado, but his name slips my memory ... Jeff ____ ) indicates that he finds molybdenum content equals harder to sharpen. If so, tradeoff should make sharpening the same if not a bit better for S30V vs. BG-42.
[side bar 1: I consider 440V to be fairly well obsoleted by 420V. My read of the Crucible literature leads me to believe that Crucible thinks the same thing. 440V doesn't do anything as well as 420V from what I can tell. Best I can figure, 440V might be somewhat easier for the production vendors to deal with both in grinding and heat treating (slightly lower austenizing temp). Otherwise, 440V is more brittle and less corrosion resistant than 420V.]
[side bar 2: Phil Wilson commented to me that Bob Loveless really liked A2's edge holding and toughness, and suggested that if he hadn't committed to making a stainless knife as one of his primary goals, he'd have otherwise settled on A2 long ago. This is what prompted Wilson to look into 3V, since 3V is a "souped up CPM version of A2" more or less.]
In some brief correspondance with Phil Wilson, he mentioned the following, and I quote (don't think he'd mind my posting part of his EMail, since I just bought a really great 420V semi-skinner knife from him :D ):
I did an article on S30V for Blade [Magazine] and may be out this coming issue. [S30V] is very good stuff.
You hit it right on the head. fits between 154CM and 420V. Based on my initial impressions with a fillet knife and a utility hunter it holds an edge better than S60V [440V] (it's pretty close to 3V at Rc 60) and is easier to finish than S90V [420V] or 10V.
Toughness seems to be very good.
Steel is about half the cost of S90V also. I think it will be my steel of choice for fillet knives. Still like S90V and 10V for the hunters [hunting knives] just for the edge holding and aggressive cutting.
The 1.5% carbon will be high enough for snappy heat treating and formation of a generous amount of Vanadium Carbides for wear resistance at the edge without contributing to finish problems on the blade surface. The carbon will also combine with Vanadium (the strongest carbide former) and leave enough chromium free for strong corrosion resistance. Molybdenum at 2.0% will yield excellent resistance to pitting type corrosion.
Thanks Rdangerer for that very informative post. This looks like it is going to really work out well for a great steel for knives. It seems to be up there with any of the other stainless steels and the cost is reasonable.
