- Jun 11, 2006
So this is a first out of the thousands of blades I have heat treated. This is cpm-S90V from jantz and I fallowed crucibles HT schedule to a T. We don’t get a ton of the more exotic alloys in for HT so when we do we default to the manufactures schedules unless it’s a steel that’s proven to benefit from low tempers and cryo.
these blades where 309 foil wrapped and soaked for 20min at 2125° (crucible calls for 2100-2200 for 10-30 min). Thy where then both pulled out and put between quench plates and slowed to cool. When I cut open the foil I noticed one had cracked and opened up quite a bit. I looked it over and the crack has a slight discoloring that’s conducive to steel that’s heated inside a foil with very little oxygen. This points to the crack forming in the oven. If it happened during the plate quench I don't think it would of discolored as the steel would bee under that color forming temp by the time it started to harden up.
I then cryo treated both blades and gave them a temper cycle. We have tempered up to 600° so far and the blades are still at 61-62+. From looking over the charts it looks like it should hit around 58-59 at 500°. I then ran a circle of tests around the hole in the tang where the crack is and found more weirdness. The bottom side of the hole that’s not cracked is really soft at 56-58 and the other upper area is 61-62. I tested along the length of the tang and it all measured 61-62.
This has got me scratching my head as to what caused this to happen. My first thought was it’s not S90V but then how does that explain the soft patch. Also am I correct in assuming that softer steel is smaller on the molecular scale. I know in blades that I have clay coated thy have a tendency for the point to rise.
Here are the pictures, what’s your thoughts?
