- Feb 28, 2002
I've had this problem with 154CM before. The attached drawing shows the surface of a small (1/4" wide) flat area above the grind after going to mirror polish. I can just see this with the light the right way. The drawing is my attempt to describe what I see under an Optivisor
At first I though it was a haze given by the grease from the buffing compound. I tried every thing to make this go away: I went back through the sanding steps 3 times, once starting from 220, once from 600 grit and once using EDM stones nothing works.
This is not the first time this has happened and it is always with 154CM. The steel is from Crucible/ Paul Bos HT. What I have been doing is turning the knife into a satin finish piece. That's okay, but I did have different finish/Handle material plans.
Any ideas before I send this off to Crucible?? I'm off for the day on my motorcycle I'll check back later
Bob
Bob
