Same test you're referring to, Wayne. My Native, Military, and Kershaw Boa will all pop a single fine hair at the touch. I don't bother with testing by "patch" shaving when I'm talking about "super-sharp", as then pressure and technique play too much into the equation.
The stones are standard Sharpmaker 204 medium and fine stones, set in the "edge" slots, although I don't let them get dull enough to use the medium stones. Touch ups consist of ten passes (5 each side) on the corners, and then ten on the flats of the stones. And I ain't no sharpenin' pro. Heaven help the blade I try reprofiling.
Truth be told, I also have less sharp (by this test) blades of 440V, and the "sharpest" blade I own is a convex edged CPM-3V blade. The AUS steels, by my experience, can also be sharpened well, but they lose the edge quickly, and to a greater extent than most others.
I have yet to find a steel that can't be made super sharp, with enough work and the right hand. That's why I try to guage my opinion more on the durability of the edge, and how quickly they move off of the ability to just touch them up and into the need for more abrasive media.
I find CPM 440V to be an excellent steel in these terms.
This is a judgement which can also be mitigated by how easily, once on the stones, a relatively durable edge returns. ATS-34, for example is great in these terms.
