all of my satin emersons have rusted on me as well, I work a very physical job and sweat like crazy and at the end of the shift when i empty my pockets there will be a slight coat of rust on the blade, I tried tuff glide to prevent it and it didn't help still had surface rust, so I ended up selling my satin emersons and replacing them with the same models only this time the ones with black coating on the blade.
I think it's kind of silly for something marketed as a hard use blade and with the price tag they fetch. I guess I just assumed that they were coated or something in order to extend the life of the blade. I haven't had mine for a year yet and Im getting this issue...kind of stupid I think.
This might sound strange but, your body chemistry can contribute to accelerated oxidation/corrosion. If you have a higly acidic pH then you might be in for a rough time with some types of steel. All the satin finished Emersons are wiped with Tufcloth from what I understand. The fact that your knife has some corrosion has nothing to do with the ability of the knife to perform it's intended functions. What you might also consider doing is using some renwax or carnuba wax on the blade after you clean it. Good luck.I think it's kind of silly for something marketed as a hard use blade and with the price tag they fetch. I guess I just assumed that they were coated or something in order to extend the life of the blade. I haven't had mine for a year yet and Im getting this issue...kind of stupid I think.
