Hi everyone,
I have been edc'd my 7 today for the first time and noticed that when I try to close it that the first few degrees are quite rough and not as smooth as I would like it.
Opening it is fine, smooth all the way. Closing, except for the initial movement is fine and smooth as well. I tried playing with the pivot screw to where it was really tight and I could not realistically open it comfortably to loose enough that the side will rub against the liner as I open it.
I took it apart a few minutes ago, and it looks fine. No scratches or dents or dirt anywhere near the hole of the blade and the surrounding area.. Put it back the way it was and still have that tightness and roughness on the closing.
Should I try to lube it or something? If so, what should I use and how much of it
THanks once again, Emerson forum!
