- Mar 4, 2008
I just got a CQC8 and a Super CQC8. I noticed that the cqc8 had a little blade play regardless of how much i tightened the pivot screw. If I pressed hard enough the blade would actually close so I sent it in. Now, since I was a little worried, I inspected my super cqc8 and noticed that the lock up was good, however, if enough pressure is applied side to side, there is very slight yet detectable movement. If I tighten the pivot screw, it will not do this, however, after a few openings, the screw loosens to where it wants to be and it happens again. Is this normal or should I send in the super cqc8 as well?
