Would appreciate some feedback, new to the forum. Recently received an axe from my girlfriends dad. Believe it to be a hults bruck agdor Montreal pattern 3.5lbs. Handle was original as it had a red epoxy top, but too loose to use so I removed it, in hopes to re haft. All I could do was tap epoxy out then drive handle out. Easy enough...no kerf, no wedge. I then gave the head a vinegar bath and when I removed some of the rust I noticed a crack running parallel to the bottom of the pole about a half inch up. Middle of crack is leading edge of the eye. Is this from heat treat in manufacture? Or could it have happened when I drove the epoxy'd haft out(no kerf)
Any thoughts?
Cheers!
Any thoughts?
Cheers!
