The biggest newbie mistake is clamping the scales on HARD. You only use light pressure spring clamps. Just enough to hold them in place is all you want. If clamped hard, you create what is called a glue starved joint.
Tips for successful handle mounting:
Finish the blade sanding completely before installing the handle - All that should be left to do on the blade is put on the final sharp edge.
Use a firm mechanical mounting system - Corby Bolts, Loveless fasteners, sex bolts, etc.
Use 24 hour cure epoxy or other high bonding resin- System Three T-88, G-flex, Loctite 324 speedbonder and activator 7649.
Prepare the surface - Sand the back of the wood with 50 to 80 grit belt/sandpaper. This creates a surface that the epoxy/resin can grip. Sand the tang under the handle to 120 grit. Use a Dremel or the corner of a contact wheel to make a slight hollow in the center of the tang under the scales. This created a glue reservoir.
Clean the surfaces - Use denatured alcohol to clean the bonding surfaces before glue-up.
DON'T Over-clamp - See the first line of this post.
Clean up after gluing - The solvent for uncured epoxy is denatured alcohol, the solvent once it cures is acetone. The best assemble method is to wipe away the drips and such before it dries, minimalizing the post curing cleanup. Using slow cure epoxy allows a good hour before gelling to do this.
DON'T use a knife blade to remove dried resin - That will scratch your blade. Make a brass graver from a piece of 1/4" round brass to cut away any excess at the junction of the handle and the ricasso.
