So, a while back I asked how and why my wood scales cracked and I got a bunch of info.
I have since used that info to obtain dry wood(using a moisture meter) that has also been kiln dried(suppose to take even more moisture out from the cells and not let it back in is what I was told).
Got myself a Vacuum kit and Cactus juice as a stabilizing agent upon which I followed the directions on the cactus juice.
My wood was heavier when it was done, and it sanded a bit different and very pleasant to work with. I put my scales on a knife and now 3 days later one is cracked and have not been in a rapid changing enviroment.
So does stabilized wood crack still or did I just have really bad luck, 1 is cracked, another seem to have shrunk a tiny bit.
And can I repair the cracked one by filling in with epoxy or just start over on the scale? They both feel very solid and theres no wiggle room there.
*edit* The scales are made of Pearwood
Await your responds!
thanks!
thanks!
