broom since you have one. would it be possible to move the motor back and put a 3step pully on the drive wheel.
I also measured the tracking knob bolt that I use, just to save you some time at the hardware store. It is 1/4"x1 1/4" with a thread pitch of 1/4-28. I took it off before I took the tension knob picture, but here is a picture of the knob itself:
Basically, I took a four armed knob from True Value/Ace, drilled out the threads and all the way through with a 1/4" bit. Then I slipped the bolt through the hole and tightened it down with a nut. It works like a freaking miracle compared to the stock hex-head bolt. .
Crank, here is a picture of the tension knob while attached:
The bolt is 5/16"x2 3/4" with a 5/16-18 thread pitch. The knob that goes over it is 2 1/4" long and tapers from a 5/8" diameter up to 13/16". I have found that this knob gets in the way a bit when grinding on the slack portion of the belt so I'm going to trim mine down in length, between 3/4-1/2 of it's current length. I'm going to try taking 1/4 of it off first and go from there. I'll let you know how it goes.
Basically, I took a four armed knob from True Value/Ace, drilled out the threads and all the way through with a 1/4" bit. Then I slipped the bolt through the hole and tightened it down with a nut. It works like a freaking miracle compared to the stock hex-head bolt. Just be careful putting it in the vise to drill it, I broke one of the arms when I tightened it too much.
Let me know if you have any other questions when you finally get it. It is a great machine and you lucked out getting an old model with the larger motor.
