- Mar 20, 1999
Couple of hours roughing out my knife blade blank.
Many more hours sanding it to about a 400 grit finish.
Ground the blade profile with my new belt sander / flesh removing machine (which, by the way, nearly ruined my knife several times).
Spent a little more time re-sanding to about a 200 grit finish.
At this point it looked like you could carry it and sharpen it.
Then built a big charcoal fire and started to heat treat the blade.
Got the blade to non-magnetic (tested with a hard drive magnet (if it won't stick to a hard drive magnet, it ain't magnetic).
Quenched in 130 degree olive oil / cooking oil mix.
Reheated the blade to non magnetic and quenched 2 more times.
So far have only drawn the knife once in the oven for about 2.5 hours at 350.
I started to sand it back down again before the final 2 drawings and have noticed a really weird blotchy pattern all over the blade. It looks terrible. This isn't just scale on the blade, the steel looks as if it melted in areas.
Is this a normal thing when working with charcoal furnaces? How can I combat it without having to buy a gas furnace?
Now it's off to find some 80 grit and a sanding block.
