Where my head is going with this is to make it structurally similar to a GIB. To me that means it needs to have the option of using a platen or a contact wheel.
Since I'd want to to be able to use REAL contact wheels, I think I'd need to have standard size (0.50") holes for the spindles. That in turn dictates the minimum size for the tool arms (no less than 0.75") which in turn dictates the minimum size of the tubing for the tool arms (1.0").
I want the thing to be able to take 30" belts or 42" belts, so the tool arms would be adjustable, as on the GIB.
Idlers are another thing. Though the contact wheel should be standard size, I'm not sure the same rule need apply to the idlers or the drive wheel. However, if not standard on the drive wheel... then what?
About the platen... seems to me you'd want the platen to be big enough to be usable, but small enough to leave room for the platen to stand off from the drive wheel. I'm thinking a 5" - 6" platen would be more than adequate, but the actual size will in part be dictated by the size, number and placement of the idlers as well as the drive wheel.
I'm also thinking this thing should be welded, instead of a weldless DIY job, but I suppose it could go either way.
