Created an edge that cuts! advice
I just picked up what has turned out to be so far beyond anything I’ve ever seen or known in a blade edge!!
I picked a custom San Mai camp/hunting 11.5” knife with (6.5” cutting edge) blade made by Rostislav Doslo and sheath/handle made by Cyril Nichols… ??? At least I hope I got this right?
The edge steel is Bohler K390 HRC 64-65 …
As this was my first time I spent a few weeks teaching myself how to use the TSPROF system and getting the some good sharpening stones to use with it.
I started with 320 grit with 14 degrees on each side then stepped up to Jende 15microns, then again Jende 3 microns and I finished using a smooth leather strop with .5 micron diamond paste and I’ve never seen anything cut like this!!!
I trained with Manaka Sensei in a traditional Japanese family Samurai system for almost twenty years and did quite a bit of cutting using Katana’s sourced from him and his top students… So I learned and am now proficient in how to set blade angles to get them moving in uniform lines so they have the best chance of cleanly getting through whatever media one may be testing or training on ie. Bamboo (green 2”- 4”), wrapped mat, or saplings and/or green branches…
With that said I took this new blade out and tested it on some softer saplings and quickly moved up to oak and was getting through 1/2” to 3/4” live branches like they weren’t really there… The Bohler K390 makes a very unique “tink” sound similar to modern alloy drivers make when connecting with golf balls.
I even cut some black locust with it and had the same experience where it got through them with ease, and after I took it home washed it off and was able to easily cut clean circles out of letter sized sheets of paper without any hitches or catching. no deformations nothing!! I am utterly flabbergasted!!? Completely blown away!!
I think what’s happened here is a combination of #1 phenomenal blade steel, #2 blade shape/geometry…
I think I got really lucky!!
And here’s what I “think” I did by choosing the sharpening techniques I chose???
I think by using the 320 grit and 14degree angle, the 320 grit possibility left high peaks and troughs in the edge steel, which the flatter higher grade Jende stones never got down to so those toothy troughs that heavy non-uniform 320 grit was left deeper in the edge??
Then I went ahead and mirrored the upper blade steel edge? Leaving it with a kinda toothy serration???? And that may be why this cuts so ridiculously well???
But as this was my very first time putting an edge on a super premium steel this is just a theory for me???!! .
K390 at 64-65 is a great steel for slicing through abrasive materials.
I wouldn't beat or chop a knife with it, there are generally better steels to Beat on.
Go get yourself some
AEB-L
1V
8670
80crv2
A8Mod
What you are doing is driving a Ferrari through a farm field.....
I followed your advice and started with a small AEB-L EDC, a Kizer Drop Bear 2 and I absolutely adore the aebl, it sharpens like nothing else and cuts even better than k390?? Which for me is a conundrum….Why does it score so low with edge retention??
I’m learning knife steels and knife steel reviews and scoring is not at all straightforward and sometimes isn’t very logical??
Logic would dictate harder = higher scores in edge retention??? But that’s not always the case??
I also picked up my first custom hand forged canister, a 15” chainsaw chain canister with a bar of 80crv2 running thru the meat of the spine and powered 1095, he melted range brass for the guard and pomme… ziricote between from Ironhead Forge, in Iberia, MO made it and wow! Over the moon with it! A real work horse I’m not afraid to actually use!! Wish I had it years ago when I was processing 10-15 cords of hardwood at my sisters homestead in VT!!!
I put a video short on YouTube hacking and shaving hard birch bark then slicing paper with it.. typing Cannister Damascus in YouTube brings it up for me…
I luv the AEB-L so much I just ordered Kizer’s new 7” fixed… think it’s 5mm thick for only $80… don’t understand knife steel prices??
Anyway, I really appreciated and connected with your response…. I think you realized I was a bit overwhelmed at the time, taking way too much knife, and knife steel data in way too fast!! Not to mention my first physical experience with a modern super steel!!
Your comment was brilliant! Driving a Ferrari thru a field!!
I’m hooked!! And grateful you took the time to respond to me!! All the best!!
Some steels like AEB-L are very fine grain, and durable. It does not have huge, Hard carbide in it. ....
It's easy to grind AEB-L Very thin.
The thinner the edge, the less force it takes to push through stuff.
The less forces scrubbing against its sides, the less wear and tear.
Very thin edges stay sharper than thick, beefy edges.
Some super thin chefs knives can literally be dull. No edge, and they will still slice through meat and veggies.
