CRK Damascus
ras
How does the Damascus steel used by CRK compare to S30V in terms of toughness, taking and holding an edge and ease of sharpening? S30V is pretty good steel; besides looking better with all those neat designs, is the Damascus better steel?
I may be wrong, but I always looked at Damascus as a steel that's just as good and in some cases better than the better steels used today w/regard to taking and holding an edge, however, it has the added benefit of aesthetic beauty and uniqueness. So you get a knife that's just as good but with a unique appearance. As a collector, appearance & uniqueness is important to me, hence the draw to Damascus. Note, this is just one's guy's opinion and I've no data to back it up ;)
CRK uses Damascus from a few different makers. As far as toughness goes any steel that is not a mixture will be tougher due to the grain structure, chemical comp, heat treat, etc. If you wanna check out what type of Damascus CRK uses click here.
Thanks, I went through the Devin Thomas site last night as well as the Crucible Steel website's data sheets looking for answers. Unfortunately, none do a direct head-to-head comparison of CM steels with Damascus.
Devin uses AEB - L and 304, so you'd need to find a steel
chart that has both of those, average their chracteristics, then compare that average to s30v.
That still doesn't deal with specifics of heat tretments but it might help.
AEB-L and 304 mix isn't the only one used, and a newer one he is using AEB-L and ATS-34, which should cut even better, and Chris Reeve bought a bunch while at the Eugene Oregon show.
