CRK Mnandi with spot on titanium
I just received this new CRK Mnandi from GPknives.com. I saw this spot on it almost immediately, I tried to clean it with the included cloth with no change. I did not want to try anything else more aggressive. What is your opinion? Return it? I am not sure what that spot even is. Thanks!
You could try isopropyl alcohol on a q-tip. That won't hurt anything. There are other stronger things like lacquer thinner or acetone but I would not go there if you are concerned about the adjacent insert.
Personally, I wouldn't let that bother me, but only you can say if the knife meets your expectations. If isopropyl doesn't work, I'd try a little bit of zippo lighter fluid on a Q Tip.
Is it removable gunk, or a stain or indentation? I'd scratch at it with a fingernail to see if it's something on the surface. I don't think you can remove a stain, and you can't remove an indentation.
Try some windex on a rag and see if that lifts it, I beleive that is what CRK recommends
