CRKT 3" Crawford/Kasper and a pivot problem
calyth
#!/bin/sh of a man
Gaucho: Been through your review... spectacular.
I must say that you were unhappy about the draw... I found the most natural draw for me is to grab the scale inside the pocket, and put my finger in the concave part of the clip. I never slipped with the draw.
It seems that the clip and the pivot screws that I have on the C/K doesn't like me necessarily. The clip have a tendency of loosening, so I did find the clerk with the T5 screwdriver, take out the screws, and put blue locktite in it, and then it seems to fix the loosening. It was loosening very fast. Although I don't use the knife often, I do "play" (more like marvel) around with it, and remove and putting it back to the pocket, and it seems easy to loosen because the only threaded part is the liner, but the scales doesn't hold the screws like the M16-Z does.
The main problem is that somehow, when I try to tighten the pivot, it seems that after a couple of flicks (which are really tight), it opens easily again. The problem is that the knife can be flicked open on a circular motion, which I would much prefer not happen easily. It seems that pivot is kinda like, how do i describe it.... it's loose, and then you turn a bit, pass its loose point, and then becomes really tight. I found this rather strange.
Anyone knows how to fix this? I'm planning to put some blue locktite and then tighten to the level I wished.
put some loctite on the pivot pin, have had to do this w/several of mine, will fix it right up
sifu
