- Jan 28, 2001
Picked up a couple of new CRKT's today. The Allen Elishewitz designed Anubis and the Tom Krein designed Dogfish.
Specs:
Blade: Length: 3.50” (8.9 cm)
Thickness: 0.14” (0.35 cm)
Steel: AUS 8, 56-58 HRC
Closed: Handle length: 4.75” (12.1 cm)
Open: Overall length: 8.125” (20.6 cm)
Weight: 6.4 oz. (181 g)
The Anubis is a hefty full sized folder constructed with typical CRKT materials: a bead blasted AUS8 blade, stainless steel frame and Zytel scales/stainless steel bolster. Of course, it's fit and finish is nowhere near that of a custom Elishewitz Anubis, but not bad for a production folder. Although I wish CRKT would use G10 or wood scales and higher grade steels, their execution of the Anubis is actually quite good.
Here's a pic of the knife's spine:
The folder locks via a button lock that's actually quite strong. This is one of the few production folders I own that locks up with authority. No bladeplay in any direction. The knife also employs the AutoLAWKS mechanism which engages automatically as you open the knife and prevents the blade from accidentally closing on you. At first, disengaging the AutoLAWKS before releasing the button lock will feel odd, but after 3 or 4 repeated opening/closing it will become natural. The Anubis uses dual M16-like thumbstuds top open and like the CRKT M16 series, the thumbstuds act as a blade stop. Speaking of the blade, it's fairly thick and has a gold plated Elishewitz logo insert that looks nice, but serves no purpose other than a decorative one. The black scales have a faux wood grain appearance which adds some nice texture to the knife's handle and they contrast nicely with the stainless steel bolsters on the back end of the handle. Like the insert on the blade, the bolsters are decorative, but they also minimize any flex in the handle. Curiously, the blade lack the Taiwan stamp, although the box clearly states it's a product of Taiwan.
Here's a closeup of the blade insert.
Although the Anubis is a great looking & solid work knife as it is, could you imagine what a folder it would be if it had G10 scales and at the very least a VG-10 blade? Add a lanyard hole and a reversible clip and it would be to die for! Still, it's quite a handsome folder that should get the job done and remain easy to sharpen. Time will tell how it holds up.
Now we go to the diminutive Dogfish:
Specs:
Blade: Length: 2.25” (5.7 cm)
Steel: 3Cr13, 55-57 HRC
Knife: Overall length: 5.25” (13.3 cm)
Weight: 1.5 oz. (43 g)
This little fixed blade comes with a Kydex neck sheath and break-away chain and fits the hands rather well. It's skeletonized handle features an amusingly cool little shark motif, but the "eye" serves as a lanyard hole and the "mouth" of the dogfish serves as bottle opener. Like the Anubis above, the country of origin is missing from the blade, but the box confirms the knife is a product of China. The knife has an attractive and utilitarian wharncliffe blade and the steel is advertised as 3Cr13 which is apparently a Chinese steel. With a 55-57 HRC it should also sharpen rather easily. Considering I paid $20 bucks for it at a local B&M shop, I can't complain and I think it would make an excellent little tool to add to a personal or pocket sized survival kit. Some folks might be turned off because of the rather pedestrian steel on the Dogfish, but I personally like it.
More pics:
Size comparision with a Benchmade Mini-Grip
Specs:
Specs:
More pics:
