I love many of the CRKT knives and own quite a few. Although I like them all a lot, there is one thing that would make me like several of the models even better (and I may be in the minority on this) ... to have a satin finish option on models like the KFF, Point Guard, and perhaps the M-16 as well.
The satin finish on my original Mirage Zytel not only looks good, but is easy to care for. If rust appears, it's nothing to take fine steel wool and some mineral oil to remove it. It's not such a quick and easy solution to do so for a bead blasted blade.
I've also noticed for certain cutting jobs, the satin finish seems to "slide" through a bit smoother than a bead blast...it may be a small thing, but sometimes I notice a slight "nails on chalkboard" feeling when using bead blasted knives for certain tasks.
Finally, as virtually all of my CRKT models are AUS-6, CRKT itself mentions one of the advantages of AUS-6 is its corrosion resistance. But bead blasting can negate that advantage. Especially if you use it to cut corrosive stuff, you don't always want to worry about immediately rinsing it off...a satin finish lends itself better to such situations, IMO.
Jim
Jim
