Marvy said:I got mine the other day. I paid $19.95 each. They appear well-made for the money. The blade is a sort of modified, hollow ground chisel-edged affair. It's a slip joint, meaning no lock, but as it's a Warncliff style, and very little piercing should be done, so it feels safe. It has an oval shaped thumb-hole for one-handed opening that works fairly well, and the scales are Zytel or some similar material that provides a pretty good grip.
When you open or close it, there is an audible scraping sound from the edge being sharpened. It does leave a burr on the back side (which is the left side) of the blade. It cuts well on cardboard and will slice a loosely held piece of paper. Time will tell how it holds up.
Overall, I like it. It's sorta' like a fixed-blade version of a Super Knife. The drawback is that you can't replace the blade, but it is better looking, more ergonomic, and much sturdier.
As an everyday, do most anything knife, for $20 bucks, I think it's a bargain!
As I said earlier, only time will tell.
Phry said:I bought one the other day and have been using it at work. Although the blade steel is 420j2, edge retention is obviously not an issue. The coarse edge works well for most tasks, and really shines cutting cardboard and plastic strapping. So far, I like it, and time will tell how it holds up.
