Which part of the sharpmaker lets you do 20 degrees? I thought it was only 30 and 40, and then the shallow scissors angle.... unless you laid the stones flat and sharpened horizontallly?My CRKT M16 was 1/2 serrated and ground the same way, with the primary grinds being symetrical, and the actual edge ground only on one side. When I sharpened it on the Sharpmaker, I just sharpened normally, using 20 degrees on each side. It never did even out, but it didnt hurt anything. I would think you would have to remove a great deal of metal from one side to even out the bevels. It wasnt worth it for me.
The 30 and 40 degrees referred to equate to 15 and 20 degrees per side. "15\ + /15 = 30" and "20\ + /20 = 40"Which part of the sharpmaker lets you do 20 degrees? I thought it was only 30 and 40, and then the shallow scissors angle.... unless you laid the stones flat and sharpened horizontallly?
