CRKT Minimalist Mod + Written Tutorial
Lanyard Hole:
Remove both scales with a T6 or T7 screwdriver.
You will see a circle on the bottom of each scale, simply use a drill bit the same size as the circle that is already there and drill straight through.
Once you have done that you can use a lighter to remove burs. You only need to have lighter there for no more than 1 second as you may risk melting the scales.
Hope this helps.
