- Jan 27, 2019
This little 6.6" knife with a 2.81" blade is a great little EDC fixed blade.
It's SK5 carbon steel and only 2.3 mm thick, with a high, hollow grind and super thin edge with a fine, pointy tip make it a super performer. Like an EDC scalpel.
It even has a swedge, which will further improve sliciness!
It's a Tom Krein design and a super inexpensive way to try out his ergos and design.
I'm using it in a KSF pocket sheath.
It's super light and also thin, so it dissapears in the pocket. You can also just use the stock sheath in your pocket as well, next to your wallet and it's right at home and dissapears as well.
Came decently sharp, with a good grind on it, but after a baker's dozen passes per side on a strop with green compound made a significant improvement. Carbon steel sharpens up so easily.
I normally pocket carry a BK14, which I consider to be a pocket survival knife.
I wanted something sub-3" for travel purposes (where there was a length limit) and also something just a bit shorter, for better fit in short pockets.
I was craving the ESEE CR2.5, but the 2 things I didn't find ideal were that it was only 2.5" and wanted a bit more length.
Also, the CR2.5 is a bit thick, for such a small FFG blade (too wedge'y).
The mossback B&T addresses both of these issues.
It's no where near as robust as a BK14, but it's an amazing B&T style blade that's light and slicey for EDC or B&T uses.
Cool piece! Nice G10 handles.
