- Jan 11, 2001
I acquired the medium sized model in a recent trade and wanted to make some comments on it. It is very similar in size to the small Sebenza and if I remember correctly uses the same alloy of titanium (6AL4V). The 2.75 in blade is of ATS-34 and came razor sharp. When in hand, the S-2 is really a comfortable knife. The machining and the curve of the handle gives you a really strong hold. The pocket clip is different than the Sebenza in that the S-2 is tip down. The clip looks bead blasted and is really too small for a knife this size IMO. As far as carrying goes, the knife also peaks out of your pocket a little too much. I would have rather had it be tip up and had a more concealed and safe carry. The lock up is very tight and there is no movement in any direction. The only gripe that I have had with the locking bar is that it protrudes a bit much.Under a tight grip it might be possible get in the way and become disengaged. Overall, this knife is a good knife for the money (I believe they can be found for under a hundred bucks). As far as replacing the Sebenza, it doesn't quite make the cut. However, I will be carrying it for a time while my Sebbie is on it's way back to the factory.
Thanks,
Matt
Thanks,
Matt
