- Sep 5, 2019
Has anyone else noticed that these are the exact same designs, a side from the lockup? The lockup is revolutionary but design wise it seems like a ripoff....
And the hump on the top of the handle.Front choil is different and slightly more belly in the bestech. Handle is nearly identical aside from a double lanyard hole....
Both knives feature a choil, indeed nearly ALL knives feature a choil, it's simply a question of whether or not the choil has a notch and if so how large. The "choil" is the end of the edge where it approaches the handle. That is all that it is. Once you go beyond the edge or the notch filed/cut into the choil, you are no longer discussing the choil but some other part of the knife....And the lack of choil on the BT...
I stand corrected. I always think of a choil as a useable finger choil. I’ll blame it on my Spyderco obsession.Both knives feature a choil, indeed nearly ALL knives feature a choil, it's simply a question of whether or not the choil has a notch and if so how large. The "choil" is the end of the edge where it approaches the handle. That is all that it is. Once you go beyond the edge or the notch filed/cut into the choil, you are no longer discussing the choil but some other part of the knife.
For reference:
Also, the screw placement is different.And the hump on the top of the handle.
And the blade stops.
And the additional contouring on the BT.
And the pocket clip.
And the shape of the flipper tab.
But, yes, nearly the same design, functionally.
