- Sep 5, 2005
I have a CRKT knife sharpener that I'm having problems with. The issue is a CRKT Desert Cruiser with AUS8 stainless. The blade is a single blade grind and I have no idea how to sharpen it.
I assume that since the edge is only on one side of the blade, that I'm only sharpening that side of it, right? I've gotten down the locomotion movement and have tried both the utility guide and the fine guide, both without results. Either I'm dealing with really crappy steel or I'm doing something wrong.
My primary problem is that CRKT doesn't have any information in their "detailed" instructions for how to sharpen a chisel ground blade.
Questions:
1) Are the angles used on such a blade different from other types?
2) If not, what is the most likely reason sharpening is not happening?
My blade is so dull, not only will it not shave hair from my arm, I can't even feel an edge. Now it is polished. Would that make a difference?
Thanks!
BTW, all of CRKT's serrated blades in their folders are chisel ground. Why wouldn't they cover sharpening that type of blade in the instructions?
Questions:
Thanks!
