There will be this " cross- ethnic integration . Hill knife " because a sword Tate collection in Taiwan . Mr. Lu .
After contact with him in our brainstorming to create this put [ cross- ethnic integration . Hill knife ] .
Why is the name of the intention to take this ...
Because I thought to myself ... Tate Collection sword so long. Almost anything knife everything.
Its replication . Better take some cream to make a knot . And join the modern engineering methods to interpret at home and abroad .
So I added a lot to synthesize .
First .
Taiwan's Atayal Hill -type knife , but less commonly used at home and abroad plus [ straight lines. Damascus steel ] .
Will be less reason to be. System to do this ' straight lines ' because directionality problem more prone to failure products.
Followed by a guard . Spend Chinese 'Old tip ' common hexagonal copper . Then two semi-circular copper lining .
Again ' handle ' is relatively close to American style , which is popular as a recent U.S. labor law ' one mosaic ' approach.
But I will be making its segment .
Joined the ' wrap knife root ' and the inner frame in the form of change , such as China scabbard gold with ornaments like . [ That box arc ]
But also hand- engraved in bronze sculpture of a male snake [ female snake ] to the occasion of this year's " Jin Yi Year"
And using a stable processed tabby maple stained to increase hardness and reduce distortion .
Knife and handle all of the parts are " detachable " In addition [ inner frame wooden handle ] .
Tail screws. Like a Chinese broadsword ring waving generated sound. ' Can also be used to deter the enemy '
Removing a knife or secondary care .
Sheath .
Taiwan's mountain knives are usually done half hoop and I will make it into a ' tiger maple ' all-wood stain on the flower .
Appends abrasion resistant copper with copper nails done compaction device .
There is also a three-dimensional hand- carved eagle snake Yang [ male snake ] to the occasion of this year's " Jin Yi Year"
' Because there are public health snake thing to mother ~'
Then the same knife had retained the Taiwan mountain tying Cinch features.
But I modify it because the weight back a long knife is a burden on the waist .
I'll add it to the diversity.
1 Bangsheng Cinch function. [ Taiwan mountain knife so often carry ]
(2) If a belt through direct stuck ' snake ' which is also a feature. [ U.S. parts are usually so carry ]
3 set into the leather . Knife can also be straight back alone . [ This way to carry a knife could be seen on many of the ]
4 lock leather belt . Could achieve " three-point " [ after wearing leather belt loop ] .
Reduce fatigue produced . [ This way is usually seen on the previous carrying swords . ]
Although the knife sheath . Has done its sheath knife set can not afford to fall out .
But ... I still designed a leather buckle . To withhold grip . Did a double insurance .
Finally .. also attach a handmade antlers split shank tool.
That's why I called it as a " cross- ethnic integration . Hill knife " was.
It combines more than just Taiwanese population . Instead, the world population .
I also hope that in the future can be more perfect union . More ethnic and knife .
Cross- ethnic integration . Hills knife 'Finish' the
Works Description:
Steel . 01 + L6 +1086 carbon Damascus steel . Linear pattern processing [ 119 layer ]
Gauntlets . Bronze bronze linings x2. [ Engraving process ] . Detachable approach. [ Detachable maintenance ]
Handle Material Bronze [ carved handle ] embedded tabby maple [ + staining wood stabilization process ] .
Bronze screw rings [ engraving process ] . Detachable approach. [ Detachable maintenance ]
Sheath material . Bronze [ sculpture processing ] . Tabby maple [ dyed ] . Tongding . Cowhide copper on the lock screw . Buckle .
Total length . 53.1 cm . Blade length . 35.6 cm . Total length with sheath . 61 cm
Back method .
Rope to wear traditional way to carry .
Can also be set into the leather . Use shoulder slung . Across the belt can make three portable .
Another is the shoulder strap removed. Direct use with a wide leather rings . American way straight back .
另一種是把肩背帶拆掉.直接用寬皮環使用.美式直背方式.
First .
Sheath .
Works Description:
Back method .
會出現這把"跨族群融合.山刀"是因為一位台灣收藏刀劍的大老.盧先生.
與他接觸後.在我們腦力激盪後創造出這把 [跨族群融合.山刀].
為何要取這名稱的用意...
因為我心想...大老收藏刀劍那麼久.幾乎什麼刀都有了.
與其複製.不如結取部份精華來製作.而且加入現代及國內外工法去詮釋.
所以我加入了許多來綜合.
首先.
是台灣泰雅山刀刀型.但是加上國內外較少人使用的 [直線紋.大馬士革鋼].
會少用的原因是.製做這種'直線紋'因為方向性的問題.比較容易出現失敗品.
接著是護手.用上中國'老槍頭'常用的六角型銅金屬.然後兩層半圓弧銅襯片.
再來'柄'是比較接近美式風格.這是美國最近流行的一種工法'一體鑲嵌式'做法.
不過我將其分段製作.
加入了'包住刀根'與內框形式改的如中國劍鞘的金具飾樣.[那框的弧形]
但是在青銅上還手工刻了一個 陽雕蛇[母蛇] 來應景今年的"金蛇年"
而且用的是穩定處理過的虎斑楓木染色.增加材料硬度及減少變形.
刀子與柄的所有配件均為"可拆卸式"除了[內框木柄].
尾部螺絲.有如中國大刀的環.揮舞時產生聲響.'還可用於嚇阻敵人'
或輔助拆卸刀子保養.
鞘.
通常台灣山刀都是做半邊箍的.我將它製作成'虎斑楓木'全木對花染色.
尾部加上銅片能抗磨損.與銅釘做緊實裝置.
還有同樣手工刻了一個 立體陽雕蛇[公蛇] 來應景今年的"金蛇年"
'因為有公有母才能生小蛇嘛~'
然後同樣保留了台灣山刀原來綁繩繫腰的功能.
不過我加以修改.因為刀子重背久對腰是種負擔.
我將它加入了多元化.
1.綁繩繫腰的功能.[台灣山刀通常這樣攜帶]
2.如果用皮帶穿過直接卡住'蛇'這也是一種功能.[美國部分通常這樣攜帶]
3.套入皮具.也能單獨直背刀子.[這種攜帶方式就很多刀子都能見到了]
4.皮具鎖上皮帶.就能做到"三點固定"[皮具後有穿皮帶的環].
減少疲勞感產生.[這種攜帶方式通常看到於以前軍刀.]
雖然刀子入鞘.已經做到入鞘置倒刀不掉出了.
不過...我還是設計了一個皮環釦.來釦住握柄.做了雙重保險.
最後..還附上一個手工製鹿角拆刀柄工具.
這就是我為什麼稱它作"跨族群融合.山刀"了.
它結合的不單只是台灣族群.而是世界族群.
在未來也期望我能更完美的結合.更多的族群與刀型.
跨族群融合.山刀'完成'了
作品說明:
鋼材. 01+L6+1086 高碳大馬士革鋼.直線紋處理 [119層]
護手.青銅.青銅襯片x2.[雕刻處理].可拆式做法.[可拆開保養]
柄材.青銅[雕刻處理]嵌入虎斑楓木[木材穩定化+染色處理].
青銅螺絲圈[雕刻處理]. 可拆式做法. [可拆開保養]
鞘材.青銅[雕刻處理].虎斑楓木[染色處理].銅釘.牛皮.銅對鎖螺絲.銅釦.
全長約.53.1公分.刃長約.35.6公分.含鞘總長約.61公分
背法.
可穿繩的傳統攜帶方式.
也可套入皮件.用肩斜背.還可穿過腰帶做三點攜式.
為何要取這名稱的用意...
所以我加入了許多來綜合.
首先.
不過我將其分段製作.
或輔助拆卸刀子保養.
鞘.
'因為有公有母才能生小蛇嘛~'
我將它加入了多元化.
跨族群融合.山刀'完成'了
作品說明:
背法.
可穿繩的傳統攜帶方式.
