As described on the Zubeng website.
Mr. Chen Rong-liang is bringing back the long-lost cross forging technique. Cross forging is to repeatedly bi-fold then cross-tri-fold a piece of carbon steel for 13 times, resulting in layered steel.
I'm not sure that description is going to help.
A new technique???? I doubt it.
My guess is that this means folding the steel like a taco, as seen in typical Japanese sword construction methods...and hype.
John
aside from the obvious hype I would think folding the steel would increase it's toughness in a similar fashion that plywood is tougher than regular wood planking. This is only a guess, as I don't really know.
not really, as the guy is folding it 13 times which gives it 26 layers, correct? And if I am not mistaken it is folded in both directions not just one. Seems like a lot of work. Could this be done with a steel like 52100?
If you take a square piece of steel and fold it over edge to edge, the grain will still run in the same direction. The only way you will get same effect you get with plywood the grain of each layer would have to run at 90 degrees to the ones next to it. This only works if you fold corner to corner, so maybe that is what they are doing.
