medit8
- Apr 25, 2002
I've had a varied success with drilling holes in a straight line for my guard slots using my regular drill vise, so I thought about getting a cross vise to help with this. I searched the forum for cross vise info and found some interesting info, mostly about the pros and cons about using the cross vise as a mill substitute, but I still have a few questions. I plan to clamp one to my drill press table and use it to put a hole in my guard material, then use it's functional ability to move the guard a little bit forward while remaining stationary, and then drill another hole, and then perhaps repeat one more time. I virtually always use 3/16" 1095, and with hidden tangs guards I figure I should then be able to file these holes into a (now perfectly straight) guard slot. So, what I'm wondering is if my thinking about this process is correct and if the weight of the cross drill itself will be stressful to the drill press table. Also, should I be using a 3/16" drill bit or a smaller size? I'm planning on getting this 5" vise from HF http://tinyurl.com/a3b25 It's listed as having a 1 1/4" depth, but it was actually 1 1/2" when I saw it in person. I plan on putting a piece of hard wood under the guard material as a base for the drilling,
They also have a 4" machinest cross vise and I don't know if this one would be better, but it is lighter. Also, I have no idea if the designation of "machinest" makes this vise better or worse for my needs. Any help about these questions, or any other info will be appreciated.
Thanks,
Bob
Thanks,
Bob
