Cruiser
Square_peg
I found this one at a flea market a couple months ago. It was rusty and pitted but the haft looked mostly sound aside from the nails used as wedges. There was no visible maker's mark.
Since this haft looked pretty good I decided to try and save it for re-use. One way to do this is to shave the haft below the axe head to allow the head to slide further down onto the haft. That may seem counter-intuitive but what it does is make the haft poke up through the eye. The two sides of the haft can then be trimmed, revealing the wedge(s) which can then be pulled. Thanks to forum member Steve Tall for showing us this method.
This is hard on a knife as the edge impacts the axe with each cut. But if you have a knife suited for this work then it's not a big deal. I shaved down the haft and then trimmed off the shavings with a box cutter blade.
As I trimmed away the haft I discovered the eye ridges. Some axe manufacturers used these to help keep the axe head fitted to the haft. 3 ridges on each side is how I've always found these.
With the ridges it was tough to get the head to slide down the haft but I got it down about an 1/8", enough to expose the nail heads and some fragments of the wood wedge after I had trimmed off the sides of the haft.
A flexible Japanese pull saw allowed me to cut close to the axe head without dulling the saw.
Even with the nails removed this haft was murder to get out of the eye. I had to beat it quite forcefully with a wide steel punch to knock it out. In retrospect I could have left this axe assembled as I found it and just sharpened it. The hang was plenty sound. But those nails were ugly.
Finally I had them separated and I managed to save the haft. I sanded the haft clean for refinishing with tung oil.
Next I went to work on the axe head. This thing is hard! It's one of the 3 hardest axes I've sharpened. This really surprised me on a no-name axe. But I realize that the pitting may have obscured any maker's mark.
Thankfully it need only minimal profiling and then sharpening. The hardness of the bits probably explains why so little work was needed on this axe. It took a very keen edge, easily shaving the hairs off my forearm.
I cut a new wedge out of some super-dry London Plane wood I have on hand. The haft got 2 coats of tung oil before assemble and a 3rd coat once assembled.
The re-assembled axe. I think it looks great and I'm happy that I was able to re-use the old haft. The haft is 26-3/4" after being trimmed and re-assembled.
I had to go after the rust pretty aggressively with a sanding pad on a 7-1/2 angle grinder. That removed the worst of the rust. Then I finished the job with a brass wire cup on a 4-1/2" angle grinder. Even after all that work a respectable patina survived. Now I need to make a sheath or mask for it.
Great find and good work on the restoration and rehafting.
Still ticks me off I live in such an axe desert.
Square, That sure turned out nice. I really liked your explanation of the process that you went through to get get her all set up. Great pictures too. Thanks for sharing your restoration.
Great restoration. Thanks for sharing your process, I might have to get one of those Japanese pull saws.
Looks great, Pegs. I use a hacksaw blade to make a curved cut since I don't have a Japanese pull saw.
Looks great! Thanks for the pics and explanation. I see that those ridges are failry common after all... I found that the boy's axe head I posted with the ridges had some really hard steel too.
I've also got a no name boy's axe with three ridges per side that has very hard steel. I know hard steel isn't necessarily a sign of quality but I get the feeling this is a good axe. I'll have it hung soon and put it to the test.
I've got a small DB with 2 ridges on one side and 3 on the other. When you hang these, do you cut channels for the ridges or trust in force?
Beautiful work as usual, Square Peg.
Good question. My haft was already channelled. Whether that was done before the head was fit the first time or done by the head on the way down I can't say. But I'd bet the channels in the haft were pre-cut to some degree.
All the on & off required to fit a head to a haft would just about require the channels being cut. Hickory is hard stuff. I had to lengthen the channels just to get this head seated. I'm assuming that I'll need to cut channels when I hang my other 2 eye-ridged axes. I would suggest cutting the channels about half the depth of the ridges and letting the axe head do the rest. That way the ridges will be nice an tight.
Several of us have noted that what is toughest on axe handles is prying them out of the wood when they get stuck. I speculate that the ridges help prevent damage from occurring during this prying.
I am no expert, but I did just hang a boy's axe with three ridges per side. I did not cut any grooves or channels but did spend a lot of time sliding the head on and off and using a rasp to make a real good fit before wedging. By sliding it off and on with a little bit of force, the channels were formed very shallow initially. Driving the wedge home did the trick to really set the ridges in. I don't know if that is the "right way", but I have been swing that little axe for a couple of days and the head has not come loose at all.
-Scott
Really nice work, Pegs! Looks like a great user! You always do top notch clean-ups. Makes me want to get to work on all the rust buckets I've got stashed.
Take care,
Matt
Wow, great find and great restoration!
Question: why tungsten oil over BLO, and is it better? Thanks for showing that.
Dave
Not tungsten oil, just tung oil.
Is it better? Hard to say. It's another alternative. BLO may penetrate a little deeper but it's less water resistant. I'm no expert on these finishes. I'm at the experimental stage.
Some quick reading on the web suggests that some finishing pros prefer tung oil.
