- Mar 8, 2007
I read that cryo treatment is important for stainless. I'm using 440C so I thought I should? I don't want to skip anything important with all the work I've put into these knives. I know where to buy dry ice but I'm not sure of the logistics on mixing it with Kerosene and soaking them. Can I put dry ice with Kerosene in a cooler or will it freeze and crack it? Should it be a steel container.... -100F is pretty damn cold! Do you just pour in the Kerosene and then float the ice in it? Any advice would be appreciated. Thanks.
Scott
unrelated question, in between tempering cycles, how cool should you let the blade get and for how long. I was just planning on letting come down to room temp and then running it back up in one cycle on the kiln, is that bad?
Scott
