- Aug 12, 2006
Dont want to start a flame up on the morals/shortshorts of Lynn Thompson and Cold Steel here, just giving my first impressions of the G10 AK 47 I picked up from Jay at warriors n wonders 2 hours ago.
I am comparing it to the original aluminum slab AK 47 that I also have had for about a year and which has earned a spot in my top five EDC rotation.
1) Fit n finish, quite good for the money, grind lines even and symetrical, the ussual CS Aus 8 level of sharpness, not quite Spydie sharp but shaves arm hair no problem. Locking mechanism idiot proof and ambidextrous.
2) Weight G10 to aluminum, the specs call for about a two ounce difference , that is readily noticeable with both in hand, G10 a winner here.
3) Grip n comfort, the G10 is very grippy in comparison to the Al slab version, feels much better for my personal tastes. Tip up carry, ambidextrous.
4) My old Al slab is very smooth now that its broken in, no wobble, tight lockup , etc after some very heavy use, I expect the G10 version to come up much the same only difference is the G10 slabs. I have no problem with the 8A blade, has proven to be a user friendly steel IMHO.
5) The G10 comes with blackened blade vs Als bead blast, time will tell how well this holds up, looks good when new, not sure how well it will hold up to abuse and still look good.
6) External dimensions/pivots identical between G10/Al but the G10 doesnt wave out quite as easily so far, query the G10 gripping the pant pocket too well, might need more break in time for the G10 exterior to wear in a bit. I have found my Al slab waves out very well.
7) The AK47 is so fugly it has developed a charm that grew on me, G10 or AL the G10 looks a bit nicer.
8) I ditched the "grivory" pinky hook from my AL slabber and made shims of brass tubing, this is planned for the G10 version. I find the pinky hook catches on things to much and creates a much higher ride profile than I like
getting rid of that thing is an easy mod.
9) Price difference G10 to AL , about twenty bucks
10) Say what you want about Cold Steel but they do make a reasonably priced solid performer in the AK47, I liked the original enough that I have gotten the G10 version as a second " user knife" with the Al slab to be relegated to left side carry now.
A
A
