Hey all,
Been lurking here for a long time. Mostly just reading and researching various knife purchases over the last number of years. I decided recently to start a couple small projects. I eventually want to get more into knife making. Right now I don't have a proper workshop/vice/tools to do too much. But I can't wait for the year or so it will take me to get there, so I decided to do a couple small projects in the mean time.
First off, I've got a CS Pipe Hawk on the way. I'm also getting a Condor Hudson Bay that should be along shortly as well. I want to do them up as a companion set basically. I'll eventually want to make or buy a bit cover and loop for the hawk. My plan is to strip the hawk and knife using permatex spray gasket remover. Then force patina with a vinegar soak. With the hawk I'm going to smooth out the eye, and possibly work on the edge geometry. May not be able to do much because I don't have a vice. May be able to get access to one. Next would be to refinish the haft. As far as the knife, I'm basically just want to treat the scales. I may or may not do some line filing to give it a bit of grip.
So basically I have some questions. I've tried to search as much as I can. Some of the info I have either not been able to find, or would like some more current opinions.
Questions:
*Is there a good reference resource for properly fitting the haft?
*I would like to try and get the haft and HB scales to match color wise, is there a stain or leather dye that might be close to the HB color?
*I would like to protect the haft and scales, but not seal (Urethane). I've considered BLO, but don't want it to be sticky. I've thought of bees wax, but then I'd have to get some neatsfoot or something to cut it with. I've thought of using something with bees wax in it like Obenauf's (I have some already) or SnoSeal. I know SnoSeal has some solvents in it that aren't that good for leathers (some say) but what about for use on wood? Opinions?
*Regarding the hawk edge geometry, is it usable if sharpened? I can probably stone it a good bit, but will it be enough?
That's what I got for now. I'll probably come up with some more for later. Thanks in advance!
Questions:
