Composition wise BD1 is closer to AISI 440b - CTS-BD1 vs. 440C vs. 8Cr13MoV vs. 440B composition comparisoniirc, cts-bd1 is comparable to 440c
Based on composition, I believe Chromium (Cr) is what affects rust prohibition. The higher the better. 8Cr13MoV has 13-14.5% Cr, CTS-BD1 has 15.75% Cr, so the CTS should have slightly better corrosion resistance. I've never used it but I have used and do use 8Cr13MoV pretty often and I've never had any rust issues with them so I think you'd be okay either way unless your using them in a salt water environment or something like that.It's been about a year since the last post and I'm wondering if anyone has any other thoughts on this. Is there a difference in the BD1 and 8CR13 with rust? A knife dealer just told me the BD1 sucks up oil and requires more maintenance, but I saw a video where someone left it in the snow for a few days without any signs of problems.
Like the OP I'm also considering the Manix2 and the Tenacious.
Interesting. I learn something new every time I'm on hereGenerally speaking you're right. Higher Cr doesn't always mean better corrosion resistance, depending on how carbides are formed and how the steel it heat treated. You can have a steel that has much higher Cr but isn't very stainless at some hardnesses because the Cr is bounded in too many carbides, and can't act to prevent corrosion. The opposite is also possible, but generally, higher Cr will mean more stainless.
Also, the usual heat treat for 8cr13mov is very simple, but comes to a general hardness and isn't very exact. Some examples are going to be notably harder than others, and because of that will have different properties overall.
From what I undertsand of BD-1, Spyderco's heat treat on it is much more exact, so it will be a more consistant product as well.
But, to be honest, I haven't had much hands-on experience with either of these steels in more than a year, so I don't really have much besides this information on them.
Interesting. I learn something new every time I'm on here![]()
