- Oct 31, 2020
Thoughts on CTS-XHP steel in a folder. How is it compared to S30V? S35VN?
Especially is it tough enough for daily uses?Thoughts on CTS-XHP steel in a folder. How is it compared to S30V? S35VN?
What are you doing that you think it would not be?Especially is it tough enough for daily uses?
Thanks.Here is Larrin:
“The edge retention of XHP is good, matching S30V and S35VN. The toughness is good as well, likely being similar to other powder metallurgy stainless steels, though independent testing has not yet been performed. XHP can attain rather high hardness for a stainless steel, about 65 Rc, which gives it some versatility in heat treatment. Despite the results of corrosion testing by Carpenter, I have reason to believe the corrosion resistance of XHP is relatively low compared to other stainless steels. XHP should be easier to finish than other PM stainless steels with high vanadium contents, giving it a good balance of ease in finishing and edge retention.”
(https://knifesteelnerds.com/2019/07/29/xhp-steel-history-and-properties/)
Thanks. Good description.Great steel, like a fine-grained D2 on steroids. My CS American Lawman in CTS-XHP takes and holds a terrific edge, and is easier to sharpen than S30V, very close toS35Vn.
Nothing specific, wire stripping, rope, vinyl ties, and twine cutting and lots of big plastic bags. Maybe stripping some branches for firewood and trimming plants.What are you doing that you think it would not be?
What brand ?? I like it a lotOne of my XHP Arii is my work beater. Has held up great, tough enough for my not so delicate use.
Koenig Arius.What brand ?? I like it a lot
Yes, that's nothing, most any knife will be able to handle that.Nothing specific, wire stripping, rope, vinyl ties, and twine cutting and lots of big plastic bags. Maybe stripping some branches for firewood and trimming plants.
I'm almost sure there is no non powder steel version of CTS XHP. That used to be called 440XH ( non powder version of what we now call XHP which was available first ) It's definitely good stuff and solves some of the problems with D2. Namely it keeps the good wear resistance while improving toughness and edge stability a bit.Just be aware if you follow the link to Larrin's work (above), it's not the powder version (i.e. CTS), just regular XHP (as far as I can tell
