cuda first run screw
can anyone tell me what size screw is used on a camillus cuda first run? pulled knife out of drawer and one of the screws is missing. any help would be great if i can get a replacement. it's one of the three set's of the handle screws,seems to be 1/4 inch long torx screw.thanks
it's the sliding disk model. has the black handle like the first one and the blade of the second one. the screws are more like the first one such as the torx head are very small and harder to see as in the first black disc model.
View attachment 901979 View attachment 901978 The screw is a 1/4”X#2-56TPI SS flat head with a #8 TORX recess. The stainless steel screw is a #2 (wire size) .086” diameter, 1/4” long (measuring overall length on flat head screws, under the head on others), with 56 threads per inch. #8 TORX bits are available at many hardware stores. The screws are available on line from knife supply companies if you have an accurate description. Camillus went out of business, so you can’t get a part from the factory.
